Multifunction DAQ
USB-6363 accuracy
I have a couple questions about the accuracy of the 6363 DAC and use. We have some engineers that have incorporated this unit into a test box. They have assigned 24 hour specifications.  Are there any 24 hour specifications for this unit? When the 6363 is inside the test box, the temperature being reported by the 6363 is typically between 45C and 50C. They claim this is not an issue even though the manual specifically states the upper limit to 45C. They said the 45C limit is strictly for the air around it, which runs typically between 25C and 30C. Which is the correct answer for the temperature? Thank you for your responses.
(465 Views)
I would assume the specification states for the temperature measured by the components inside the DAQ.
Santhosh
Soliton Technologies
(436 Views)
