Multifunction DAQ
USB-6341
Hi all,
Can the DIO voltage of USB-6341 be maintained? As far as I know, the logic high will be varies in between 2.2V-5V.
(2,589 Views)
That specification is for the input voltage to be considered a logic High.  The output is a 5V TTL and will only drop from the 5V when the current limit on the line is reached.
GCentral
(2,546 Views)
So means that we cannot set a static output voltage for DIO is it?
Is it possible to set a value for DIO output voltage if we add pulldown resistor or potentiometer?
(2,531 Views)
It'd be better to add some isolation by using your DO to operate something like a relay to  control an independent supply of DC voltage.
-Kevin P
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW? (Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
(2,524 Views)
