03-20-2012 06:58 PM
Hi - If i connect +5V (pin96) to AI 0 (pin1) on my USB-6341 will the AI 0 only draw a minimum current to see the 5 volts or will I burn out the channel/resistor?
Thanks in advance.
03-21-2012 01:00 PM
Hello C2PO
You can connect it and measure the 5V without blowing the channel. This a very common test that you can do when you suspect that the AI is not working properly and you want to check it against a know voltage source.
Warm regards
Mart G
03-21-2012 04:11 PM
Thanks. I'll try it out.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
