07-27-2010 09:17 AM
I want to drive some 12VDC solenoid valves using a USB 6216 and RFD3055s. Do I need to add a gate voltage drive transistor due to the difference between gate to source (5V) and drain to source (12V)?
Fet and valve datasheets attached.
The valves can probably be driven using a 2N2222 but I wanted to build a something that can drive larger loads also.
Thanks!
Ed V.
07-27-2010 10:59 AM
It works now I had the load on the "wrong side" of the drain source circuit.
