I'm a newbie to Labview. I'm using Labview 2009 and USB-6009. i tried to use USB-6009 to display sinewave input signal from function generator. First, the sinewave look perfect at the frequency 1KHz but when i changed to frequency to 10KHz, the sinewave turned into triangle wave. When i test input signal, i set the sampling rate is 48KHz and terminal configuration is RSE. Is there any problem with USB-6009?
