Multifunction DAQ
USB-6009, NI-DAQ 6.1.1 and LabVIEW 6.1
Dear,
We have just acquired the USB-6009 and in the
installation manual there is a reference on "how to
install NIDAQ-mx".
We would like to know if it is possible to use this
acquisition board with NI-DAQ 6.1.1 and LabVIEW 6.1?
If not, there is an easy way to convert VIs from
LabVIEW 6.1 to LabVIEW 7?
Thanks in advance,
Danilo Melges
Student
Biomedical Engineering Program
COPPE/Federal University of Rio de Janeiro
Brazil
(3,737 Views)
I think that you cannot use LabVIEW 6.0/6.1, since USB 6009 has only DAQmx support .NI-DAQmx 7.5 or higher or NI-DAQmx Base to be more precise
And these are supported by LabVIEW 7.0 or higher.
so consider moving on to this higher version of LabVIEW
regards
Dev
(3,735 Views)
HI Danilo-
devchander is correct- your USB-6009 is only supported by NI-DAQmx which in turn is only supported by LabVIEW 7.0 and later.  A VI written in LabVIEW 6.1 will (in most cases) open fine in LabVIEW 7.0 without modification, but the fact that you must use a newer driver may necessitate rewriting the DAQ portion of your code in order to use NI-DAQmx with your device.
Hopefully this helps-
Tom W
(3,729 Views)
Hi Devchander and Tom,
Thanks for your help! I will follow your sugestions.
Danilo Melges
Student
Brazil
(3,716 Views)
