Multifunction DAQ
USB-6009怎样配置
导师提供了一个USB-6009,我们的实验课题是“基于虚拟仪器的多参数生理信号检测系统”,我要怎样配置数据采集卡,急需大佬们指教,谢谢!
(2,648 Views)
This is an English forum. According to Google Translate, you asked:
The instructor provided a USB-6009. Our experimental topic is “Multi-parameter physiological signal detection system based on virtual instrument”. How do I configure the data acquisition card? I urgently need to advise you, thank you!
Based on this, I recommend you follow the DAQmx Getting Started guide: Getting Started with NI-DAQmx: Main Page.
Moreover, depending on the type of measurement you will do, I suggest looking into the LabVIEW Examples: Help > Find Examples > Hardware Input and Output > DAQmx.
Good luck with your project.
(2,490 Views)
Ok, Thank you, if I need it, I'll ask you again!
(2,475 Views)
