05-10-2018 03:13 PM
I inherited a USB-6008 and have never used it. I'm trying to measure the period over which a circuit is closed. Can the USB-6008 be used for this? I don't need extreme accuracy (within 0.1 sec is sufficient). I'm fine using the internal PC clock.
The input signal is simply a relay that is opens and closes. I want to measure when the relay is closed. I don't currently have an installed version of LabView, so being able to do this manually with NI-DAQmx would be best. Is that possible?
Any ideas? I'm fairly new at this so simple explanations are much appreciated.
05-10-2018 08:28 PM
USB-6008 doesn't have internal clock for Digital Input so, you can use internal PC clock only.
If the application isn't complex, I believe you can run your application within 0.1sec.
But there is a possibility of delay once the load of CPU increases.
By the way, DIO on USB-6008 is open collector. Is it OK?
05-11-2018 02:41 PM
Thanks, Emboar. To answer your question about DIO being open collector, I don't even know what that means, so I have no idea.
Do you have any suggestions on how I would hook up the USB-6008? As I said, I'm pretty new at this, so if you can point me to a tutorial or something, that would be helpful.
Thanks in advance.
05-13-2018 07:20 PM - edited 05-13-2018 07:20 PM
Read this user manual.
On page 16, you can see how to connect a switch to USB-6008.
http://home.hit.no/~finnh/videos/topics/labview_analog_io/371303.pdf
Is this helpful for you?
