Multifunction DAQ
USB-6008 outputs high on start
i am using a USB-6008 and i registered a high state or max volts on every output (Digital and Analog) on start. So the first thing i do is to set the voltages or states to low. But if I restart the outputs are set to high again.
On our HiL testing system with PXIe 6739 everything works fine. All outputs are low on start.
Does any1 have an idea why the USB-6008 is doing that?
Thanks for help. 🙂
Greetings
(192 Views)
Accepted by topic author p_dieng
You can find answer to your question here.
It just built in that way))
__________________________________________
The best way to thank, is to give KUDOS
(150 Views)
