USB-6008 Plug-in replacement
Hello all.
We use the USB-6008 in a machine. Now we need to replace this defective device.
The question is: Is there a channel, where we can buy these modules again, they are no more listet at NI. Or is there a plug-in replacement-module that needs no software-change?
Unfortunately there is no possibility at NI Homepage to ask this question, in my opinion a very bad behaviour, but maybe the community can help me?
Thanks for any reply
Bosshard
(775 Views)
If you do a search for USB-6008, there is a link there to "Contact Us".  You can probably use that to get a hold of somebody in NI to buy one.
But if you are looking for a replacement, it would be helpful if you told us what functionality and requirements you need.  Software-wise, almost any DAQ from NI will use the DAQmx.  You should state what version of DAQmx you are using as well so we can double check compatibility.
GCentral
(758 Views)
Hi Bosshard,
Did you ever find a drop-in replacement for the USB-6008?
Ben
(638 Views)
No, unfortunately not. There was no real help from NI.
Mabe you can find some used parts on market-platforms like eBay.
We switched to a different hard-soft-platform with better availability.
Regards
Urs
(628 Views)
