Multifunction DAQ
USB-6008 Measurment Accuracy?
Hi, I have a 2.0VDC signal run into this board with Pin 1= GND and Pin2=2VDC. When I perform a mesurement, I read out +.5VDC?? I'm running the sample application fro the NI-DAQ CD called ContAcq-IntClk.c.
Why is there ~1.5VDC offset?
rjmiller
(2,945 Views)
Hi RJ-
The problem you're seeing is discussed in this KB.  Basically, you are wiring your input in an RSE terminal configuration so you need to indicate that explicitly in your code with the DAQmxCreateAIVoltageChan function.
Thanks-
Tom W
(2,940 Views)
That'll do it - thanks Tom.
rjmiller
(2,938 Views)
Hi RJ-
Glad I could help- keep us posted if you run into any other problems.  Thanks a lot-
Tom W
(2,929 Views)
