06-22-2012 12:04 PM
I'm using a USB 6008 to read analogue voltage signals from a device I built. The task is set up with single ended reading with a range of + -10 volts. There is no scaling in the task or the block diagram but when I acquire the data to a TDMS file and view it, I get a load of PieceWisePolynomial scaling properties. I've attached the TDMS viewer to this post.
Does anybody know where this comes from because I can't explain it.
Thank you,
06-25-2012 05:10 PM
The data is coming back as an unsigned integer between 0 and 32k from the ADC on the 6008.
The scale is converting that unsigned int to a floating point value between -10 and 10.
06-26-2012 03:33 PM
Thank you Snowpunter
