06-30-2011 09:28 AM
I am using the USB-6008 device in a new application to first read the analog values and then fire solenoids based on the readings. The current limitation on the USB-6008 is 8.5 ma as per the specs and the device I want to drive is rated 5v at 38 ma. Does anyone know of an application to increase the output of the USB-6008, such as with a transistor or analog switch?
RDD
Solved! Go to Solution.
06-30-2011 09:43 AM
You can use one of the ULN2xxx relay drivers.
06-30-2011 10:28 AM
Thanks Dennis,
This should work nicely.
RDD
07-02-2011 10:55 PM
I didnt know that... thanks for posting it out
Best Regards
