‎06-26-2016 06:02 PM
‎06-29-2016 02:52 AM
Hi Beshboy,
as long as it will be a constant value, the AO and AI will work just fine. Problems start when you wan to have simultaneous generation and acquisition. Note: I am not sure what you want to use the 2,5V for, but be aware it has very limited current output - 5mA).
When it comes to Matlab - I am not experience with using it for acquisition, but it should work with this toolbox.
‎06-30-2017 05:42 PM
Beshboy,
Were you ever able to confirm if you could get the constant voltage out with the USB 6001 to power your device(s) and record analog input? I also want to use a 6001 to power an inverting amplifier and a provide a voltage across a bridge circuit and then measure the voltage across a variable resistor using the analog input channels on the 6001 and I'd like to do it all in Matlab. If you can, would you share your code in Matlab to specify the voltage on the AO?
