Multifunction DAQ
USB-6001 max DIO update freq. of FIFO size
Highlighted
I looked in the datasheet and I only found a max update freq. and fifo size for the analoge pins.
What about the digital pins ?
Do they also have a 2048 bytes fifo ?
I need to send and read around 256 at more then 10k Hz ?
Steve
(814 Views)
Highlighted
Accepted by topic author Trianon
With a USB-6001 you can only set/read DIOs with software-timing. It is not possible to use the internal hardware-clock. Hence it won't be possible to read or send DIOs at a rate of 10 kHz with that card.
Regards, Jens
Kudos are welcome...
(780 Views)
