Multifunction DAQ
USB-6001 OEM Pin 1
Can anyone confirm the location of pin #1 on the 34 pin connector?  I assume it's as indicated on the attachment but want to be sure before I design a custom interface PWB.
Thank you.
(2,629 Views)
Hello!
You can verify the pinout here:
NI USB-6001/6002/6003 OEM User Guide
http://www.ni.com/pdf/manuals/374261a.pdf#page=3
USB-6001 Pinout
http://www.ni.com/documentation/en/multifunction-io-device/latest/usb-6001/pinout/
Hope this helps!
Levi D.
Technical Support Engineer
(2,567 Views)
Thank you for the reply.
I am looking to identify Pin 1 on the NI-USB-6001 OEM connector.  If you look at:
the drawing shows dimensions but does not identify pin 1.  I found the attached for the NI USB-6000-OEM where pin 1 is identified.  I am assuming the identification of pin 1 is the same for the USB-6001-OEM as it is for the USB-6000-OEM.  Can you confirm?
Thank you.
Regards.
(2,548 Views)
Sorry for the misunderstanding. Based on the OEM User Guide for the USB-6000-OEM and the dimensional drawing of the USB-6001-OEM found here:
cu_usb-600x-oem.pdf
http://www.ni.com/content/dam/web/dimensional-drawings/2014/cu_usb-600x-oem.pdf
the identification of pin 1 is in fact the same for the USB-6001-OEM as the USB-6000-OEM.
Levi D.
(2,535 Views)
Thank you.....that's what I was looking for.
(2,516 Views)
