07-22-2019 09:52 AM
Can anyone confirm the location of pin #1 on the 34 pin connector? I assume it's as indicated on the attachment but want to be sure before I design a custom interface PWB.
Thank you.
07-23-2019 10:17 AM
Hello!
You can verify the pinout here:
NI USB-6001/6002/6003 OEM User Guide
http://www.ni.com/pdf/manuals/374261a.pdf#page=3
USB-6001 Pinout
http://www.ni.com/documentation/en/multifunction-io-device/latest/usb-6001/pinout/
Hope this helps!
07-24-2019 09:20 AM
Thank you for the reply.
I am looking to identify Pin 1 on the NI-USB-6001 OEM connector. If you look at:
the drawing shows dimensions but does not identify pin 1. I found the attached for the NI USB-6000-OEM where pin 1 is identified. I am assuming the identification of pin 1 is the same for the USB-6001-OEM as it is for the USB-6000-OEM. Can you confirm?
Thank you.
Regards.
07-24-2019 10:52 AM - edited 07-24-2019 11:17 AM
Sorry for the misunderstanding. Based on the OEM User Guide for the USB-6000-OEM and the dimensional drawing of the USB-6001-OEM found here:
cu_usb-600x-oem.pdf
http://www.ni.com/content/dam/web/dimensional-drawings/2014/cu_usb-600x-oem.pdf
the identification of pin 1 is in fact the same for the USB-6001-OEM as the USB-6000-OEM.
07-24-2019 03:44 PM
Thank you.....that's what I was looking for.
