Multifunction DAQ
USB-6001 AIGND DGND and the USB GND
Hello.
Is the diffrent ground on the USB-6001 DAQ are isolated from each other?
im intrested espacilly in the AGNDD and DGNd are they isolated from each other?
and are they isolated from the USB supply GND?
i couldn`t find the answer in the spec nor the user guide.
have a great day, and thanks in advance
(2,050 Views)
Usually, the AI and DIO ground are connected to the chassis ground, unless the datasheet mentions something else explicitly.
Isolation from the Chassis Ground for NI DAQ Hardware
There is no isolation for low-cost DAQ like USB-6001.
https://tmesystems.net/
(2,023 Views)
@johndoe_1987 wrote:
Hello.
As long as you don't see the word "isolated" in the datasheet, all grounds are internally tied up eventually.
Santhosh
Soliton Technologies
(2,017 Views)
Accepted by topic author johndoe_1987
There is a simple way to check: use a DMM to check the continuity between AGND and DGND.  I have not used this specific model, but generally speaking for DAQ boards the AGND and DGND use their own planes in the board and then are connected at a single point (usually a single via).  With other boards I have used, these also had a single point connection to chassis ground as well, which would be the USB GND in this case.
(2,008 Views)
