Cal-Specs are smaller to cover all the drifts over the calibration interval!
Drift due to time (internal references drift) , temperature!, humidity ... noise, self heating of the sensing resistors ...
Well specified (usually metrological) devices have 24h, 1 month and 1 year specs ...
IF you have known currents (sources) (or even better known stable exiters for your current sourcing transducers, say weigth loads for a loadcell) and do a lot of calibrations/verifications over a longer periode, you can estinate how good your setup really is.
And don't mix up accuracy and resolution 😉
Greetings from Germany
Henrik
LV since v3.1
