You are seeing this error becasue the task that you have defined is an Analog Input>>Thermocouple. To correct this, you should use an Analog Input>>Voltage, and then you will be able to define volts as your prescaled units. When you have a thermocouple task, it is expecting some type of degree measurment, which makes sense. Try this, and let me know if you have any further questions. Have a Great Day!
