07-07-2015 09:38 AM
I'm currently trying to set up a LabView code in order to get readings of voltage using 5 different locations simultaneously. I want to only use the first location as ground and obtain 4 voltage measurements between the ground and each one of the other 4 channels. I'm using a usb 6000 which for now allows me to use the same ground for only two channels. Is there a way to use the same ground for 4 channels?
Thank you,
Maria
Solved! Go to Solution.
07-07-2015 10:15 AM
07-07-2015 10:25 AM
I have electrodes placed in 5 locations but one of them will be connected to the ground pin and the other 4 to the analog channels. The problem is that the technician told me that I shouldn't connect the same ground reference to more than one pin. Is that true? You have to understand that this is the first time I'm using a DAQ that's why I'm so confused.
Thank you
07-07-2015 10:34 AM
07-07-2015 10:56 AM
07-07-2015 11:19 AM - edited 07-07-2015 11:25 AM
You're right it is confusing the way I describe it so I ahve attached some pictures of the set up. The first figure is the cell filled with soil and the 5 probes inserted in it. The anode is placed at the left end of the cell and the cathode at the right end but they do not appear in the figure. I'm trying to use location 1 as gournd and take measurements of voltage from the following pairs: 1-2, 1-3, 1-4, and 1-5. The second figure is the DAQ I'm using. When I was trying to set up the RSE configuration, it was ussing ground A for the channels 6 & 7 (locations 2 and 3 in figure 1) but ground B for channels 4 & 5 (locations 4 and 5 in figure 1). What I am asking is which is the best way to use the signal from location 1 as the ground for all 4 channels. Is this more clear?
Thank you for your time!
Maria
07-07-2015 11:46 AM
