Triggering without analog trigger circuity
I am new to LabVIEW and DAQ applications, so apologies if my question is naive.
I am using a PXIe-6341 MIO module in a PXI 1071 chassis.
In my application I need to read an analog input signal and trigger a counter pulses generation, when the analog signal crosses a value of voltage in a sinusoidal oscillation experiment
I figured out that the MIO module doesn't support analog triggering as it doesn't have analog triggering circuity.
What do you think that is the best way to build up a software trigger vi as effectively as possible??
Also do you know if the counter pulses (that will trigger a camera acquisition), can be implemented in a loop?
Thanks in advance,
Nikos
(719 Views)
The best way to use DAQ for control is to use Hardware-Timed Single Point Mode.
Application case 1 of NI-DAQmx Hardware-Timed Single Point Lateness Checking should match your use case.
Control Lead | Intelline Inc
(687 Views)
Dear ZYOng,
Thanks a lot for your reply. It seems that the software triggering is not fast enough for this application.
Do you know if I can configure the trigger with the PXIe-4138 source measure unit?
Nikos
(660 Views)
You can trigger using 4138 but the SMU does not have any means of triggering based on output voltage and there are other sorts of synchronization possible.
Santhosh
Soliton Technologies
(652 Views)
