Hello, I want to acquire an external signal from an analogic input and I want to use an external signal (from an photo-cellul) to start the acquisition. I use the same structure that in the "Acquire N scans Digital Trig.vi". But it doesn't work. It seems that I don't connect the signal in the good pin. Can you help me. Thanks
Tao, Be sure that you are connecting the digital trigger signal to PFI0, as that is the line that this examples looks at for the trigger signal. On a standard 68-pin connector block, that is pin 11.
