Triggering AO with ai/StartTrigger and with certain delay
I have a USB 6366 simultaneous DAQ and want to use ai start trigger to trigger AO as well, but with certain delay time. Basically I want AI task to start first and then start AO task 10ms later.
I used below code to use AI start trigger for AO:
DAQmxErrChk (GetTerminalNameWithDevPrefix(AItaskHandle,"ai/StartTrigger",trigName));   // function to get AI trigger name
DAQmxErrChk (DAQmxCfgDigEdgeStartTrig(AOtaskHandle,trigName,DAQmx_Val_Rising)); // Set AO start trigger as AI start trigger
And below code will start both AI and AO tasks at the same time, but want AO start 10ms later...
DAQmxErrChk (DAQmxStartTask(AOtaskHandle));
DAQmxErrChk(DAQmxStartTask(AItaskHandle));
Can I change the duration of AI start trigger so I can use its falling edge to trigger AO? If so, how should I do?
DAQmxErrChk (DAQmxCfgDigEdgeStartTrig(AOtaskHandle,trigName,DAQmx_Val_Falling)); // Set AO start trigger as AI start trigger
(1,167 Views)
I don't know the text language syntax, but in LabVIEW there's a "trigger property node" that let's me set "trigger delay"=0.010 and "delay units"=seconds.  It ran without error for me on a simulated lower-end X-series device, so I expect it should be supported for your higher-end real device.  But again, I don't know the text language syntax needed to configure it that way.   It's probably available from any of the C variants and probably Python, but based on prior conversations I'd be less confident about Matlab support.
-Kevin P
(1,141 Views)
Thanks for the tip. I found similar old post for such problem and used its suggestion below. It seems working.
DAQmxSetStartTrigDelayUnits(AOtaskHandle , DAQmx_Val_Seconds);
DAQmxSetStartTrigDelay(AOtaskHandle, .00000002
(1,136 Views)
