12-04-2007 04:52 PM
12-07-2007 05:08 AM
Hello fjedgar,
From my understanding, You are using LabVIEW and both a 6036E and USB-6008. You mention that you are only able to use your
digital trigger to control ai0 on both devices.
The USB-6008 has 8 analog inputs, 2 analog outputs, 12 DIO channels and 1 counter. The USB-6008 supports digital triggering on the analog inputs. The digital trigger must be on PFI0 and can be used on all ai lines as a start trigger.
According to the User guide and specifications the 6036E family of devices does support digital triggering for analog inputs. The 6036E has a digital trigger that can be used as a start, reference and pause trigger. If you are using the DAQcard 6036E then the trigger you cannot have external sources as your trigger. Depending on whether you are using the PCI or DAQcard version of this card, the triggering options will be different. Which 6036E are you using?
You should be able to trigger more than just one of your analog inputs on both cards. I would like you to test this out with a program from the LabVIEW example finder. Open LabVIEW and go to Help>>Find Examples. In the Example finder, go to the "search" tab and search for "trigger". Next open the example called Cont Acq&Graph Voltage-Analog SW Trigger.vi. Please test is out on your other analog input lines and let me know if you still experience the same problem with triggering. Make sure to select the correct device and trigger line according to what device you have selected.
I hope this helps!
