01-18-2013 04:20 AM
Hello all,
I have an application in C that needs to play 3 wavefiles simultaneously on 3 NI PCI-6733 cards.
I am implementing this on:
OpenSUSE 8.2
NI-DAQmx 8.0.1
Following the samples from the SDK.
For various applications, I need to provide a choice to play:
- externally triggered via PFI1 on all 3 cards, or play immediately
- externally synchronized via PFI0 on all 3 cards, or play using internal clock
What I find out is that:
- internal clock with no triggering works
- external synchronization with no triggering works (a TTL clock signal on PFI0). The signal plays normally if I connect the external clock signal, and playback hangs if I do not connect it. This is expected.
- external triggering does not work (a TTL triggr signal on PFI1). The signal playback hangs, whatever signal I put to PFI1, even if I connect the clock signal to PFI1 instead of PFI0.
The code that I use:
if (extTrig)
res = DAQmxCfgDigEdgeStartTrig(analogTasks[card],
DAQ_EXTERNALSAMPLETRIGGER,
extTrigRising ? DAQmx_Val_Rising : DAQmx_Val_Falling);
Check("Set External Trigger Analog", res);
where:
extTrig = TRUE
extTrigRising = FALSE
DAQ_EXTERNALSAMPLETRIGGER = "PFI1"
Check() is a function that prints an error message from DAQmxGetErrorString if res isn't zero
No error message was printed.
Any ideas?
01-18-2013 01:47 PM
Does the playback start on all three and hang later?
You could try triggering just one card and exporting the start trigger (DAQmx_Val_StartTrigger) to PFI2 and have the other two cards trigger off of PFI2
http://zone.ni.com/reference/en-XX/help/370471W-01/daqmxcfunc/daqmxexportsignal/
-gavin
