08-20-2014 05:07 AM
I have a PCI-6036E installed in a Windows 7 (32bit) PC and I am trying to run some old software using Traditional NI-DAQ. I have downloaded and sucessfully installed the latest Legacy Driver (Ver 7.5). The device shows up in MAX (ver 4.6.2) under Device and Interfaces and also under Traditional NI-DAQ (Legacy) Devices
So far so good.
I the tried to load a .daq configuration file I had from the old software but nothing happend and Data Neighborhood remained empty.
I then decided to recreate the channels from scratch and could do this - All channels appeared in Data Neighborhood. I saved the configuration using the Save Configuration As in Tools, Traditional NI-DAQ Configuration with no error messages and the .daq file appeared on my Hard Drive.
I closed MAX and contiued with my LabVIEW program but it could not find my named channels. I reopened MAX to check the spelling etc and found the Data Neighborhood was empty. Tried loading the previously Saved Configuration and Data Neighborhood remaind empty.
Can anybody help as I dont want to have to a) leave MAX open continuously or b) reneter all my channels everytime I open MAX
The old program was LabVIEW 7.1 and I am converting it to LabVIEW 2009
Ken
08-20-2014 06:16 AM
You do realize that Traditional DAQ is not supported in Windows 7. Sounds like you are running into an issue due to that limitation. I highly recommend rewriting your project using DAQmx since that will continue to see support for a very long time.
08-20-2014 06:39 AM
Not according to where I downloaded the Legacy driver from!
Considered rewriting for DAQmx but only need to use the application 1 more time then I can retire it
Ken
08-20-2014 06:50 AM
Well that's news to me. I did manage to find that download as well as this quick KB: http://digital.ni.com/public.nsf/allkb/8EC9E81C3DE4E619862573930083BD7A
Ok, I'm stumped as far as your problem then.
08-20-2014 06:54 AM
Thanks for your response anyway. i have fired off a Service Request to NI to see if they have any ideas.
If they come up with anything I will post it.
Tempted to find an XP machine, Fit the DAQ Card, Load LabVIEW 7.1 and run it from there
Ken
08-21-2014 06:23 AM
Hi Ken,
My name's Max and I'm an application engineer here at NI- thank you for contacting us. I think I may have found a link that can help with your problem, please take a look at this and let me know if you think it will be useful.
http://www.ni.com/download/traditional-ni-daq-compatibility-vis-1.3/822/en/
Best of luck!
Max
08-21-2014 06:43 AM
That is for Windows 2000/XP/NT with LabVIEW 7.x.
I am using LabVIEW 2009 in Windows 7 trying to use Traditional NI-DAQ whilst converting an application originally written in LabVEIW 7.1
Thanks anyway
Ken
09-05-2014 09:52 AM
To solve this, do the following:
In MAX, load .DAQ file.
Click Save all.
Close Max.
Reopen Max.
No channels appear at this point.
Create new traditional DAQ channel.
Right click the new created channel and click properties.
In the drop down box to select channel, you should now see all your channels.
Select one of those channels and press okay.
All the channels should now appear in MAX and you should be able to close MAX and reopen it and all the channels will still be there.
I hope this helps!
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
