Multifunction DAQ
Three Displacement Transducer requires external 8.5 : 32 vdc power supply
Three SM4x9 Inductive displacement transducer to be connected with USB 6002 Analog Input in
differential configuration .. External 8.5 to 32 vdc power supply must be used to power the transducer
,SM4x9 Transducer -ve Signal output and -ve power supply share same pin 2 (-UB) .
-How to connect the transducer and external power supply to USB 6002 in differential mode ?
is it ok to connect:
External power supply -ve and Transducer pin2(-UB) and USB 6002 AI GND
all together?
Attached :SM4x9 data sheet and connector pin assignment
(1,861 Views)
Although this connection makes sense to have everything referenced to one ground. I would be ideal to check on the specifications of the USB 6002 since this is only a USB powered device and the current specifications for the external power supply, make sure that they can work together. The external power supply can go up to 32 VDC, and this is pretty high for this type of device.
(1,819 Views)
