Multifunction DAQ
The suitable data acquisition card for an application.
I am running a system with five measuring instruments. Two thermocouples, two differential pressure transducers and one flowmeter.
I receive analog signal from all of them. mV from thermocouple, voltage in range between 0 and 10 volt from differential pressure transducers and current in in range between 4 and 20 mA from the flowmeter.
I need to acquire data by 100 samples per second rate, for almost 1 minute. I need to be accurate in my data measurements, especially that recorded from the thermocouples.
Could you please recommend me the suitable data acquisition card for that application.
(2,046 Views)
Hi Gheit79,
I recommend calling your local NI number (If UK it is 01635523545) and one of NI's inside sales team will happily be able to help you scope this piece of hardware for you in no time at all!
Kindest Regards,
Matt
(2,004 Views)
