Thanks for contacting National Instruments support. The specifications say that this sampling rate is for both channels simultaneously. Using two cards will not affect the rate of the ADCs on the boards. Let me know if you have further questions.
Kenn North Principal Product Manager - Search, Digital Analytics http://ni.com/search
I stand corrected. I will put in an error in the documentation, it should say per channel, or each channel. A look at this devzone at the bottom shows the true answer, that there is 663,000 samples per channel.
Sorry for the confusion.
