Multifunction DAQ
The nidmfuiu.mxx plug-in caused an exception in the CmxAggregateItemUI::GetSpeci
I keep getting this error when i self test the devices in NI-9712 ...
I am not sure how to go ahead...
(4,609 Views)
Will this help you? Post back.
Mathan
(4,603 Views)
this leads me to the link
http://digital.ni.com/public.nsf/allkb/6CA56E2DDBCCA06086257591006141EE?OpenDocument
i already checked this out.. it just gives me an option to neglect the error,, but even when i do that it doesnt seem to set right the propblem. the device still doesn't get ready to acquire signals...
(4,601 Views)
and by the way can you please tell me where to get NIMAX version 4.6 for labview express. seems that would solve the problem..
i cant find it in LabVIEW site..
(4,599 Views)
Hi, Shanky1023.
MAX 4.6 installs with NI-DAQmx 8.9.5 (reference:  http://digital.ni.com/public.nsf/allkb/EE0FB9EB80AE148686257336006CED22).  To obtain MAX 4.6, download this DAQmx driver.
The screenshot provided in the first post seems to be corrupted.  Can you attach another screenshot of this error or type out the error code/message?
Sara Lewandroski
Applications Engineer | National Instruments
(4,586 Views)
Hi Sara..
Thanks for helping  out.. When i got the error msg last time i choose "Dont show me this error again.."  now it doesnt show me the error..Let me describe the problem to you in steps.
1. When i try to configure these devices in MAX-4.6 by right clicking on say NI-9205 it gives me an error that the device has failed the Self Test. I am attaching the error in a file named MAX_1 .
Now coming to LabVIEW signal express i tried to connect a thermocouple T-Type to NI-9213 and acquire signals.. I connected one thermocouple to a0 port and tried to calibrate but it gives me a DAQ error...
I am attaching the error as SignalExpress_1 ,
Basically the units in the chassis (Ni-9205, 9213, 9265 etc dont get detected at all and not able to acquire signals.)
Could you please help me out..
I am also in the manwhile trying to Download NI-DAQmx 9.0 . i am using 8.9 until now.. but i am not sure whats the problem in 8.9. this problem may still persist in DAQ-mx 9.0
(4,579 Views)
Hi, Shanky1023.
This issue has been resolved in past issues by doing a repair on the DAQmx driver (Go to Add or Remove Programs in the Control Panel.  Select National Instruments Software and click the Change/Remove button.  On the National Instruments Software dialog box, select NI-DAQmx x.x.x, and click Repair.).  I noted that you were in the process of upgrading to DAQmx 9.0.  This may also resolve the issue.  Let me know how the upgrade works out for you.
Sara Lewandroski
(4,546 Views)
