07-16-2010 04:34 PM
07-19-2010 04:58 PM
Is this initialization error repeatable? The knowledgebase article you linked references a particular feature of some x86 processors called Physical Address Extension (PAE) that enables more than 4GB of physical memory to be used in 32-bit systems. Not necessarily that you are using a server. Do you have PAE enabled? What Version of DAQmx are you using? Can you open Measurement and Automation Explorer and see and use your device there?
07-20-2010 05:21 PM - edited 07-20-2010 05:31 PM
06-27-2011 06:18 AM
Hello All,
Can anyone provide the solution to this error. I am getting the same problem.
While restart getting Devenv error and DAQmx vis giving nilvaiu.dll failure and not able to open MAX. DAQmx 9.3.0 installed into my system recently.
1. I tried to reinstall all my DAXmx drivers
2. I tried to disable PAE using /execute= alwaysoff /NOPAE
3. I tried to set /maxmem=4096
nothing seems to workout for me.
My PC is having LAbview 7.1 and Labview 8.6 drivers
Windows XP service pack 2, recently I upgraded my RAM from 1 GB to 2GM and Harddisk memory upgraded to 80GM from 40GB.
Thanks In Advance.
06-28-2011 10:05 AM - edited 06-28-2011 10:07 AM
Was the system working before you tried to upgrade DAQmx 9.3? DAQmx 9.3 will not work with LabVIEW 7.1. The most recent DAQmx that will work with LabVIEW 7.1 is DAQmx 8.9. Can you uninstall the 9.3 version and install 8.9? What exactly do you mean by LabVIEW 8.6 drivers? Do you mean the drivers that shipped with LabVIEW 8.6, or do you mean DAQmx 8.6?
Jon S
