12-04-2007 03:35 PM
12-04-2007 04:38 PM
Hello the_intern,
The AI SENSE and AI SENSE2 channels on the NI PCI-6289 card are the card’s references for the analog input channels. AI SENSE covers AI channels <1…15> and AI SENSE2 covers channels <16…63> and <64…79> as described on page 3-2 of the M Series User Manual. There are a number of sensors that you can use to test the AI SENSE and AI SENSE2 pins on your card and it depends on which sensor you have as to how you wire the sensor. See page 4-14 of the M Series User Manual for a summary of the different connection types (in the pages following this table it describes in more detail how to choose which one to use). If you have a floating signal sensor then you can test the AI SENSE pins by using either a non-referenced single ended (NRSE) or referenced single ended (RSE) connection to test the channel. If your sensor is grounded then you should only use NRSE since using RSE with a grounded sensor may cause a ground loop and damage either the card or the sensor.
The reserved lines of the NI PCI-6541 are “reserved for future use, do connect to these pins” as per page 17 of the NI Digital Waveform Generator/Analyzer Getting Started Guide which covers your card. This means that they should not be tested.
I hope this helps!
12-04-2007 04:56 PM
Thanks Brooks_C,
But then what are AI GND for ?
My NI PCI 6289 has 32 AI [AI 0 through AI 31]. Where do you see all the way up to 79?
If I connect AO 0 (i.e 6.5V) to all 32 AI lines, does it mean that AI SENSE and AI SENSE should be conected to the same ground [GND] / referrence as the AO 0 ground is ?
I definitely want to use Analog Output voltage for all 32 AI lines...
12-05-2007 10:52 AM
12-06-2007 09:10 AM
Thanks Neil,
This is my plan for the Analog Input lines. I am going to connect AO 0 of lets say 6V to all 32 AI lines having resistor in between each as a voltage drop, so that each AI lines read slight lower voltage than 6V. In this case, I would leave SENSE and SENSE 2 connect to the AO GND that AO 0 is using or to the AI GND, or the the main power GND?
How about testing the PFI lines (16 of them). As I understand, only tow of those lines are actually counters, whereas other 14 are just additional features for the CTR, therefore can be tested as static DIO. Connect one to another and test their connectivity by W/R high/low... Any thought on testing these 16 PFI lines ?
12-06-2007 11:53 AM
Can I connect PFI 14 (frequency out) to PFI 12 (CTR 0) and to PFI 13 (CTR1) and test those two counters in that way ?
What frequency can I generate from PFI 14 ?
12-07-2007 12:52 PM - edited 12-07-2007 12:54 PM
