‎12-17-2007 02:16 PM
‎12-17-2007 02:58 PM
‎12-18-2007 11:50 AM
Hi Greg,
You said that you tried importing the last programmer's configuration from within the project. I'm assuming that means that you opened on the configuration utility from inside LabVIEW. The following knowledgebase talks about being about to choose your device (CF-6004) and the need to open the configuration utility from within LabVIEW. It also has information about loading examples tasks to access the CF-6004. If this doesn't work, you should probably reinstall the drivers and start over. Hopefully though, the reason that your device is not showing up is the way that you are accessing the configuration.
Also usually the error -200525 is associated with trying to perform some type of action like digital on an anlog channel or vice versa. Hopefully once you device has been found and the original problem is fixed and you are reading the correct configurations, this error will be resolved.
‎12-20-2007 09:45 AM
