TTL signal using a NI USB 6211 and python code?
I need to using python code in order to generate a TTL signal out of a NI USB 6211, how do I accomplish this?
(4,221 Views)
you would need the DAQmx driver installed from ni.com/drivers (http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/ssnav:drv/q/daqmx/) and then you can try out https://pythonhosted.org/PyDAQmx/index.html
(4,200 Views)
