From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
02-03-2006 01:02 PM
02-03-2006 01:19 PM
02-03-2006 10:04 PM
Are you using DAQmx or traditional DAQ??
02-04-2006 12:42 AM
02-06-2006 09:41 AM
Hi jayjay-
Which development environment are you using? Can you please elaborate on how you weren't able to synch the boards? Did you run an example program, and if so did you receive errors? Or do you just need a bit of help with getting started? Any time you can provide some information about your efforts and problems so far it makes it significantly easier for others to help you out.
Assuming you are using LabVIEW, I have attached an example VI that shows how to synch two boards for analog output using a RTSI cable and Traditional NI-DAQ. If you need further suggestions please respond to this thread with more information about your setup.
Hopefully this helps-
08-11-2010 10:55 AM
Tom (if you're still out there),
The VI that you mention below (Output_Sync_Traditional.vi) sounds like it contains exactly what I am looking for. However, I do not seem to be able to open this with LabVIEW 5.1.1 (I know that this is a very old version, but I'm just trying to modify some 'legacy' software). Is there any chance of me getting a copy of this for LabVIEW 5.1.1? How about a screen-shot of the VI?
Todd
08-11-2010 01:35 PM - edited 08-11-2010 01:35 PM
