Switch between Multiple measuring Points
You would need a 4-wire 4 channel multiplexer. Typically multiplexer are part of a complex test rack and most come in high density and not at this low channel count and rarely a USB version.
What is your budget? if you go for a cheap multiplexer, the trace and contact resistance of the multiplexer degrades your measurement accuracy.
Santhosh
Soliton Technologies
Message 11 of 12
(997 Views)
With my 15min google search, this is a possible simplest low cost COTS solution
https://www.wireflow.com/products/io-modules/c-series/wf-3132-multiplexer-module/
along with https://www.ni.com/en-us/shop/model/cdaq-9171.html
Santhosh
Message 12 of 12
(995 Views)
