09-21-2019 10:28 AM
The latest version of NI-DAQmx for linux 19.1 appears not to support cDAQ-9181, according to the README file at URL http://www.ni.com/download/ni-linux-device-drivers-2019/8283/en/
Are there any plans to provide a linux driver for this chassis?
Thanks.
09-24-2019 07:01 AM
Hello there,
I'm sorry to say that there's no information regarding plans to release Linux driver for the chassis. The workaround, that you might've already tried is to use a Virtual Machine instead.
Thank you.
09-24-2019 08:11 AM
It is unfortunate that NI chose to treat Linux as a second-class citizen, considering its clear lead over windows in embedded applications. When making a selection, I did not expect that an ethernet-based device would be so poorly supported. The experience will without question influence my future decisions and recommendations to colleagues.
09-26-2019 08:06 AM
The cDAQ-9185 and cDAQ-9189 Ethernet chassis are supported in NI-DAQmx 19.1 for Linux.
The cDAQ-9181 is part of an older generation of chassis and is not currently supported.
