02-10-2006 02:52 PM
02-13-2006 09:01 AM
02-13-2006 09:35 AM
The thing that I am wondering is if I need a VI that will send out data via COM port.
Also, does Labview sees a wireless connection as a COM port?
In order to make this work I need a vi that sends data (PDA) and a vi that saves it (PC).
Am I correct?
Do I need an add on to develop VI to work with wireless setup?
02-15-2006 11:53 AM
Hi Fede,
Yes you would need a VI running on both the PDA and the host computer (one to send the data and one to receive it). If they are on the same network, then you should be able to communicate between the two using the network protocol of your choice (tcp or udp). There is an sender/receiver example for both TCP and UDP in the LabVIEW 8 example finder. Keep in mind that with UDP there is no error checking, so data can be lost.
Best of luck!
Chris J
02-27-2006 03:44 PM
I checked those examples but what I am not clear about is on how to select the communication port.
in the TCP listen VI how do you tell labview to check the wireless card for the check for network addrress?
The TCP open connection VI opens the communication. How does it know on which device?
I am new to this and I do not want you guys to do it for me. I am just looking for some things that I can read and the examples are not helping me much.
02-28-2006 05:16 PM
Hi Fede,
The TCP Listen and Open connection VIs have a port input where you can specify the port to use. Outside of that everything is handled by the operating system.
Cheers,
Chris J
02-28-2006 07:13 PM
I am sorry If I sound stupid, but how do you exactly choose a wireless card or ethernet port?
Thanks for your help
03-06-2006 09:57 AM
03-07-2006 01:42 PM
03-07-2006 08:34 PM
What I would like to do is read the data that the PDA is reading in the client PC and save that data simulataneously.
I have a VI that reads and saves on the PDA and the next of the project is going to try to get that data sent over TCP/IP from the PDA to the PC.
I am trying to create a live telemetry for a race car.
I could probably use the current VI that saves and add to it few lines that will allow the PDA to send the data with WiFI technology.
I was trying to use data sockets but Labview PDA doesn't support them so I will try to see I can use the active and passive TCP/IP VIs.
Also, is there a way to specify the TCP/IP address of the PDA with labview since I cannot find the IP address of the pocket pc.
