is there an easy way to Stop the pulse generation from
the DAQmxCreateCOPulseCharFreq function by an external
digital trigger signal?
I am aware of the possibility to use an Pause trigger to interrupt the generation on a digital trigger but this does not stop the task.
The application is to run a stepper motor until the motor generates an TTL level signaling that it's maximum range has been reached. Is there a better approach to this task?
Thanks for any advice!
Peter
