06-03-2008 04:47 AM
06-09-2008 09:45 AM
06-10-2008 03:18 AM
Dear Sir,
Thank you for your post on our website.
What you are trying to do is handshaking. The M series DAQ boards are not a ideal solution for this kind of digital in / output. A better solution is a digital in and output card (for example PCI6536; http://sine.ni.com/nips/cds/view/p/lang/en/nid/202772 )
Based on this solution you can find a example in the example finder from Labview (search on handshaking). Please find also some examples on our web; http://zone.ni.com/devzone/cda/epd/p/id/3796
f you add your VI is can review it to look if speeding up is possible.
Martijn S
NI NL
06-10-2008 04:03 AM
06-12-2008 02:53 AM
Dear Tom,
I'm still working to figure out what is the best way to implement this. There is a difference between the ports; lines 15,16,19 and 22 are static (software timed), the performance depends on your system. At this moment I wanted to share a example (change detection). I hope this will be helpfull, but besides that I will come back to you as soon as possible.
Martijn S
National Instrumetns NL
06-12-2008 06:28 AM
Dear Tom,
Ass promised some additional information on my last post.
To achieve the 1 MHz DIO speed (only on port 0) you need to correlate your digital output lines, a example for this can be found under this link; ttp://sine.ni.com/devzone/cda/epd/p/id/1566
Please not that after every send there will be a software call for a handshakes. The handling time of this call depends entirely on your system performance. With cards which do support handshaking the handshaking will be done onboard; so no software calls are needed.
By using the RTSI bus you will be able to synchronize a digital i/o card with your PCI 6229. Another solution is to use a R series (FPGA) card. With FPGA you will be able to program the handshaking on the DAQ card itself; so also no software calls. These cards are also available with analog in and output besides the DIO. PLease note that you will need Labview FPGA to program this kind of hardware. Please find the FPGA solution with this link; http://sine.ni.com/nips/cds/view/p/lang/en/nid/202005
If you haven any questions, please don't hesitate to contact me.
Martijn S
National Instruments Netherlands.
0348-433466
