NI 6040E PCI, PXI 16 SE/8 DI 12 bits 500 kS/s ±0.05 to ±10 V 2 12 bits 1 MS/s ±10 V 8 2, 24-bit Analog, digital
here is the questions.
1. What is the difference between the "max sampling rate" and the "output rate"?
2.I have 5 signals with the frequency 8-10kHz to be obtained and select a segment in a cycle, then make some mathematic processings. To insure the accuracy, I have to get more than 300 points in my selection. We know that the "E series" DAQ card has only one AD converter shared by all channels. Then is 6040E fast enough for my request? If not, do I have to use a faster DAQ card such as "NI 6133"?
3.Can a "NI digitizer" be made as a role here? And what is the main differences between the "digitizers" and the "DAQ cards"?
