‎04-06-2007 05:39 AM
‎04-10-2007 03:09 AM
Hey Julien
Did you use the example VI provided by LabVIEW? Did you modify it? If you did could you please post it? This error might be caused by the referencement type (Differential, referenced, non-referenced) It depends on how is your system build...
Here is a link (and an other) that may guide you through this choice.
Richard Keromen
‎04-10-2007 05:31 AM
For PCI-6250 the input terminal is configured to differential by default (ai0 with ai8), which is not suitable for my system. By changing it to NRSE, il should work properly. Thank you very much for your help !
Best,
Julien
‎04-16-2007 08:48 AM
‎04-17-2007 05:40 AM
Thank you very much for this information. It can be useful to know that.
