Hello all,
I never used the Counter/timer and DIO functionality and was wondering if anyone can help me out. In my application I currently use a PCI 6711, and find myself requiring 2 digital outputs in addition to the 4 analog outputs I already use. The analog outputs run at ~100kHz or faster, and I require that the two digital outputs will generate one pulse each with a temporal accuracy of several microseconds (therefore requiring hardware timing). Is there a way of using the digital outputs or the counter/timers to do this (or are the timers already busy timing the AO)? Is there a way of adding only one fast digital output (will provide partial relief)?
thanks in advance, Shy Shoham
