09-26-2012 04:48 PM
I know this topic appeared many times, but it seems I am still doing something wrong. I use PXI 4461 and try to simultaneously generate waveform and perform signal acquisition. I tried to follow the example Multi-Function-Synch AI-AO.vi, but I receive an error that the task is reserved. I have run out of ideas how to fix it..
I will appreciate any help.
09-27-2012 07:04 AM
Hi Kasik,
What version of DAQmx driver are you using?
There is a known issue with 8.5 version, try to install the latest one.
The KB you can see below:
http://digital.ni.com/public.nsf/allkb/8C7A7AF1A6DDD00086257399005B8513?OpenDocument
Kind regards,
Ion R.
09-27-2012 08:59 AM
Hi!
Thank you for the answer. I use DAQmx 9.5.
Now I receive error
Error -89126. Trigger line requested could not be reserved because it is already in use.
Thank you in advance for any hint..
09-28-2012 07:00 AM
Hi Kasik,
I believe at the following link you can find an example that should solve the problem
https://decibel.ni.com/content/docs/DOC-11432
Kind regards,
Ion R.
09-28-2012 09:09 AM
I tried it also.. But hmm maybe that's a stupid question, if I want to do the synchronization within one board, within PXI 4461, does it need to be on slot 2 of the chassis? If yes, then when I try to change its position to slot 2 it's not seen by the system. What am I doing wrong now?
10-02-2012 01:57 AM
Dear Kasik,
the particular slot the device is placed in is only important when there are multiple cards to syncronize in the same chassis. Regarding the error code you get, please check if there are any trigger lines reserved in MAX. You can do this in Devices and Interfaces > Triggers. Please refer to the following article for further info:
http://digital.ni.com/public.nsf/allkb/C3BA0E573766745086257A100034F053?OpenDocument
If the problem persists or you have other questions, please get back to me.
Kind regards:
Andrew Valko
10-02-2012 03:29 AM - edited 10-02-2012 03:30 AM
Apparently the link I submitted does not work anymore, so let me just copy it in here instead:
10-16-2012 02:06 AM
Works! Thank you!
10-16-2012 08:17 AM
I have one more question. I know that in order to remove the delay I should substract the number of points depending on my update rate. I'm not sure if I understand that clearly, so sorry for the stupid question. I use the property AI.FitlerDelay to get the number of points to discard - is that all? Or the number of points should be the sum of the delay in analog input and analog output? Or something else?
Thank you in advance.
10-16-2012 10:42 AM
Hi Kasik!
It's great to hear that your application works! The delay that you need to account for is dependent on your purpose with the measurement. If you, say, want to measure a response of a system, then you want the sum of output and input delays (as a sample will be propagated through the system to return back to the input, delayed by both). If you want to monitor the current system state (that is, pair up the output and input values that are observable by the system at the same time) then you'll need to subtract the output delay from the input delay. It is also a good idea to measure delay times before use, to account for possible incorrections. you can find some relevant discussion here:
I hope this helps.
Kind regards:
Andrew Valko
