Multifunction DAQ
Sample rate change - how is the sampling affected?
Hello everyone,
I have a pci-6229 board, and I am sampling an analog signal. My question is as follows, suppose that I sample at 10Hz (while the board can sample 250ks), how does this work?
Sampling at 10Hz means taking a sample every 100ms. Is the NI board really acquiring a signal this whole 100ms, or does it take a sample for for 1/250000ms, and than waits 99,9ms, and than take the next sample?
So the question is: how long does it take to get 1 sample, and (how) does setting the sample rate effect the time that the board actually take a sample?
Hope someone can clear this for me,
thanks.
(3,062 Views)
I would look at this KnowledgeBase article.  There is also more information on the sample and convert clocks in the NI-DAQmx help.
Essentially, the sample clock initiates a scan of all of your channels.  The convert clock determines when a sample is digitized.  I hope this helps.
Todd V
NI Prototyping Community
(3,026 Views)
Hello Tod,
I already found an article about sampling basics, but they didn't mention the convertclock.
thank you very much!
(3,019 Views)
