08-17-2006 08:18 AM
08-18-2006 08:17 AM - edited 08-18-2006 08:17 AM
Message Edité par Mathieu Steiner le 08-18-2006 08:19 AM
08-18-2006 08:26 AM
08-21-2006 06:49 AM
08-21-2006 06:56 AM
08-21-2006 06:59 AM
08-21-2006 07:31 AM
Hello Christian,
You are right concerning the unablity of the 6722 to acquire analog signal. I made a mistake regarding this. My intention was to make you lead test to use one of the eight analog outputs of the board using MAX. Using an external clock to clock such generation (PFI 0...9). If the test fails, the board must have a problem, if the test succeeds, wa are doing something the wrong way. You says that the board seems physically alright I need more information about the results of this test.
By the way, thanks for having attached both code and chronograms. I am currently looking deeper into...
Please keep me informed.
08-21-2006 09:22 AM
08-22-2006 01:50 AM - edited 08-22-2006 01:50 AM
Hello back Christian,
I really would appreciate if you could lead the test using MAX ... (Measurement & Automation Explorer) This would help us to go on with your concern. MAX actually is our main test tool to ensure the good functionning of a board. I wait for such a result test to have search directions regarding your problem.
Message Edité par Mathieu Steiner le 08-22-2006 01:51 AM
08-22-2006 10:12 AM
