Multifunction DAQ
Safety voltage thermocouples acquisition inputs module NI9213
I have a NI9213 module for simultaneous reading of thermocouples. I will use the thermocouples to measure the temperature in different elements, some of them will be touching parts at 250 Vac, others at 0V and others connected to earth. The module does not indicate the voltage or maximum safety voltage between channels, so I do not know if the module can be damaged if I use thermocouples at different voltages.
Thank you very much in advance for your answers,
Message 1 of 1
(1,671 Views)
