‎01-27-2008 05:46 AM
‎01-29-2008
10:04 AM
- last edited on
‎05-06-2024
05:54 PM
by
Content Cleaner
Hi Gustep,
Welcome to the forums! A few considerations when finding the SINAD of an M-series card.
1. The M-Series cards do not have a specified THD or SINAD measurement. NI does not test or guarantee any specific performance. That being said, 80dB seems reasonable. And your method for testing it sounds correct.
2. For better SINAD or THD specs, I would definitely recommend a DSA (Dynamic Signal Acquisition) board. These boards were designed with these specs in mind.
3. For a cheaper but reasonable improvement another recommendation would be to use the Higher Accuracy 628x boards. The THD and SINAD are different between our good, better, and best boards and you did not mention which card you are using. One thing to note is that NI’s M-Series boards are not very phase accurate. It is likely if you want to know the THD and SINAD, you will care about phase information and should go with DSA.
I hope this provides you with some pointers.
Mallori M.
