Hello Jeff,
I see that you are using the SCXI-1102 and specifically channel 31 is
give you some problems. Channel 31 is one of the differential input
channels on the SCXI-1102.
What are you using to test the channel?
Have you tried opening a MAX test panel to test the issue?
What settings have you selected?
Are you selecting the correct range?
Have you tried the module in a different slot?
Sandra T.
Applications Engineer | National Instruments
